Hi there
I'm installing some software that requires a cert for the internal communication from client > server.
An SSL cert seems to be required and it needs to contain the FQDN of pool that it uses. I have added the required SRV/DNS records for it but I am unable to start the services until the SSL cert is in place.
How do I go about getting an Internal SSL cert working with this?
I'm not sure if I can use self signed ones, hopefully I can.
Either way, I'm not sure how to create a self signed cert that has my internal name such as pool.domain.local
Whats the normal way of doing this?
Must I go to a CA and purchase one? If so, where's the cheapest?
