SSMS to web hosted MySQL
6 Mar 2008
Stoke area
Hi all,
I'm having some issues I hope you can help me with.
I'm with Krystal hosting and I've created a MySQL database on there via CPanel. I've created a user and I've given my home IP MySQL access.
I am using the latest version of SSMS and I am just unable to connect.
Details I have are:
IP_ADDRESS of my webhost
DBASE_NAME
SQL_ADMIN_NAME
SQL_ADMIN_PWD
So I've set SSMS to connect to a Server Type of Database Engine
Authentication is SQL Server Authentication
Login and Password are those of the SQL_ADMIN account
Server Name, I've tried just the IP_ADDRESS as well as variations of the IP_ADDRESS\DBASE_NAME but I get one of 2 errors:
named pipes provider error 40 (this is just IP address)
SQL network interfaces error 26
Any advice?
PS, Yes I've also contacted their support who advised me to allow my IP which I'd already done.
They sent me details and a port over, URL is for the same IP address I have and the port is 3306.
Still couldn't connect via SSMS but I've installed DBeaver and it downloaded, installed and connected in less than 5 minutes.
guessing it's a problem with SSMS and MySQL connections, something to troubleshoot later on.
Didn’t think that SSMS had native support for MySQL, although I did hear once you could look at setting up an connection using the MySQL ODBC driver and add a linked server to SSMS but never tried it as deemed it was just faster to use the two separate programs.
SSMS does not support MySQL. It does, however, support ODBC - so create a DSN with MySQL drivers and you should be able to do some stuff through that.
e: just noticed I'm just echoing the above.
