Hey all,
Got this game a few weeks back and got my Wii back on the weekend so finally got around to playing it a fair bit!
First Off, Graphics.
The framerate on this game is SOLID no slow down at all, no matter how fast I pound the pixelated version of me down the mountain or if there are any avalanches, or fireworks going on, it's constantly smooth and very pretty. Bit annoying that the game doesn't use the full screen and even though I've got everything set to 16:9 it still doesn't use about half an inche either side but meh, you don't notice it after a while.
Menus
Very easy to navigate, nice and colourful.
Controls
The controls are very easy to get used to and you can pick them up very quickly and give you a good feel to the game. To go forwards you use the nunchuk joystick and to make slight turns again you use the joystick, to make a sharper more severe turn (or to spray snow everywhere
) you twist the nunchuk and he will move appropriately and will carve the snow. It's done very well and doesn't feel unresponsive, but not twitchy at the same time.
For flips, spins, and ubertricks you use the wiimote, flips and spins are self explanatory, ubertricks means you have to draw shapes in the air to perform them (they do look awesome though!) sometimes using just the wiimote, or more complex tricks involve the nunchuk as well. Tricky to get used to, but once you get used to the motions and the feel and the flow you can pull them off nicely.
Oh and to jump when you come to a ramp you can either use A or twitch the nunchuk upwards and he will jump, no delays, very responsive, so you can really leave it to the last minute and then FLY - is a great feeling.
Lots to unlock throughout the game, from what I can see there are 3 peaks with lots of challenges on each one with all the charactors, about 30 playable people at a guess.
Very good game on the whole, and where the controls are so responsive it really shows what the wiimote can do, one of my biggest fears when the Wiimote was dreamt of was the response times in games and this seems to have got it spot on.
Haven't played multiplayer yet (having to much fun in single) but will let you know when I do.
Thanks for reading
Menus
Controls
) you twist the nunchuk and he will move appropriately and will carve the snow. It's done very well and doesn't feel unresponsive, but not twitchy at the same time.For flips, spins, and ubertricks you use the wiimote, flips and spins are self explanatory, ubertricks means you have to draw shapes in the air to perform them (they do look awesome though!) sometimes using just the wiimote, or more complex tricks involve the nunchuk as well. Tricky to get used to, but once you get used to the motions and the feel and the flow you can pull them off nicely.
Thanks for reading
