ST: Legacy, asteroid mission
Suspended
17 Mar 2006
I'm stuck on Star Trek Legacy, next generation mission where the planet blows up and asteroids are on a collision course with another planet.
I can take down quite a few -upto the point where you're instructed to use the turrets, but going back and forth with tractor beam means I'm not there blasting the asteroids (fellow wingmen are) but only one needs to get through. Two planets can be destroyed resulting in a failed mission. :(
The Apollo class starships (ones with a a saucer and the naecelles sticking out the top and bottom) are handy for this mission as you don't need major firepower to destroy the asteroids and they are pretty quick.
I ended up getting the stargazer to move the Turrets into position by giving order to transport them into position while I controlled the other starships for destorying asteroids. You may need to take control again for actually pacing the te turrets in the correct position. Also make sure you divert power to the engines to make the stargazer go faster.
station other ships near the planets.... once you get towing, just set it to goto the co-ords and then control the asteroid blasters...
BTW, if you think that's it, you're in for a surprise later (in the same mission!)
yeah managed to do it, the final asteroid hit the planet (the others blasted most of the rocks around it)
I think the other wingment AI is pretty poor, set them going to a waypoint and they stop- so you can't do set specific things for multiple ships. Managed to complete final mission, had to use a trainer though (I need 4 Enterprise E, and only enough money for perhaps two and keep my two lesser ships)
