Sounds more like a vacuum leak than anything, might have a slight crack in a hose somewhere or something, but could also be the pcv valve causing the same.
With a spread of codes like that lambda/oxygen sensor is the usual suspect as mentioned above, sometimes just sticking some additive/premium fuel through might be enough.
Ah, ned to repair the wiring loom there, looks like it's melted on the exhaust, seems that's your failure, make sure it's tied well out the way when it's fixed
