So guys, anyone point me in the direction of a good alternative?
Requirements:
Less than £3k (might be a BIT flexible)
Decent performance 9s or less 0-60
Comfortable for the M'way.
30mpg minimum give or take.
Basically im sounding out options for when i reach the half-way term on the VRS finance. Priorities have changed a lot and a house is around the corner.
If i can pick up a bigger engined car for cheap then i dont mind paying extra for the gas.
As for the ST24, looks like a really good option. I have read about the usual issues, i.e Plastic impellars on water pump, IMRC failure, occasional headgasket failure.
The only one that bothers me is obviously the latter. Is there a specific revision i can watch out for that worked around this, or indeed any of the problems mentioned?
Cheers,
Requirements:
Cheers,
