I'm building a SFF PC with a Silverstone ST45SF-G. The Main ATX power cable are a good length but the SATA and Molex cables to power HDDs and optical drives is quite long.
I'll post pictures later but the SATA power cable has three connectors but I only need one for my SSD. This leaves me with excess cable in my case.
Anyone know where you can purchase shorter cables? Has anyone made their own custom length cables? Can you buy the connectors to fit the PSU end? (8 pins)
Connectors:
1 x 24-pin motherboard connector (300mm)
1 x 4-pin ATX12V connector (400mm)
1 x 6-pin PCI-E connector (400mm)
1 x triple SATA connector (300mm +200mm +100mm)
1 x dual 4-pin IDE (300mm + 200mm)
1 x single floppy power connectors (300mm + 200mm + 200mm)
Connectors:
