- 18 Oct 2002
- Isle of Wight
Hello to everyone not playing in the snow...!
After a lot of troubleshooting, I just wanted to ask for some advice...
System info:
Windows XP SP3
Intel Core 2 Duo E6850
MSI P6N Diamond
4GB Corsair Memory
GeForce GTX 260 (216 Core) Black Edition (180.48 drivers)
Hiper Type-R 580 Watt Power Supply
My system is running at stock speeds but the GTX Black Edition is overclocked by default, as you no doubt know...
Fallout 3 crashes to desktop occasionaly, but I put that down to the game not my hardware. Other, somewhat older games, have had no apparent problems. However, I finally got round to trying Dead Space and Left 4 Dead recently and I have had recurring crashes of a particular type.
Left 4 Dead: Black screen / Sound Loop (needs restart)
Researched this a fair bit and I have tried everything that has been suggested. The console commands, disabling dual-core support etc... although the stuttering / lag has been solves, it still crashes to black screen and sound loops until reboot... randomly.
Dead Space: Pink corrupt screen / Sound Loop & corruption (needs restart)
Everything I have read seems to point towards dodgy graphics card or dodgy drivers / OS builds. I have tried the latest drivers but they didn't change anything, so rolled-back.
I have wiped my hard drive and started from scratch. Fresh Windows XP SP2 install, with and without SP3... latest drivers... tried and tested drivers (ones that have always seemed to work for me before)... same issues as before. CPU / GPU temperatues are well within acceptable limits. I have re-seated every component just be sure. It doesn't seem to happen that often but it's something that I really want to try and fix if it is something to do with my hardware.
Let me see... what else? I have disconnected all non-essential devices and monitored my PSU readings, all of which are normal. 3DMark06 has been allowed to run for hours and has not crashed. Memtest also reports no errors and my CPU is 24 hours stable (had to cancel the test so I could do something!)...
So then... are the games to blame? Drivers? Or should I try swapping my graphics card and / or PSU? I would have done that already but I have no spares and it's going to be a pain to do! But i'll do it if it's not likely to be a dodgy graphics card.
Sorry about the long post and thanks for reading. Look forward to getting some advice! Cheers.
After a lot of troubleshooting, I just wanted to ask for some advice...System info:
Windows XP SP3
MSI P6N Diamond
4GB Corsair Memory
I shall persevere...
will deffinatly* fix the left 4 dead problem - the default fan profile isn't agressive enough to handle certain extremes causing the VRMs to get too warm it seems theres a few threads on this.
