Posting this more in frustration and wanting to get a head start on some (more) troubleshooting later..
P9X79 Pro
3930K @ stock settings
Akasa Venom Cooler
64GB 12800 Patriot IEM
Background: Built this system back in October mainly as a VM development machine, after some initial teething troubles (RMA'd dodgy RAM kit) seemed to be running sweet. It locked up a few times but I just put this down to workloads.
However, recently it's become more unstable without being heavily loaded, this lead me to believe there is an underlying cause.
First test.. Memtest. This threw up errors on test 6 - block move. all of which seemed to be in the first MB of memory (usually at 0.2MB), so I swapped the RAM around in the slots and tried some different combinations of chips in slots and the errors still came up, again around the 0.2MB mark.
Next.. Re-seated the CPU, doesn't appear to have made any difference (other than running a little cooler with new thermal paste).
Planning to try a different CPU later, only 2011 one I can get my hands on is a Xeon E5-2609, should work for testing purposes right?
Will also try some completely different RAM too.
Am I missing anything here or does anyone have any suggestions? diagnosing issues is bad enough when you have all the gear to test everything out, but when it's higher end and you can't easily get hold of different parts it's a headache!
Thanks in anticipation of any help and pointers.
- Lanky
P9X79 Pro
Akasa Venom Cooler
- Lanky
