- 22 Dec 2012
Stability issues using 1600 memory, fine with 1333
Hi, I have a very strange problem that I am trying to get to the bottom of, but so far without much luck. I recently upgraded my computer with the following:
Gigabyte Z68AP-D3 Rev 2.0
i5 2500K
Crucial Ballistix DDR3 1600 8GB (2x4GB)
I was plagued with problems. A fresh install of Windows8 crashing left right and centre, due to a variety of BSODs. To rule out the issue being Windows8 I did a fresh install of Windows7, and had the same issues. After a load of trial and error I thought that I had found the cause of my issues, a duff memory module! If I tested them one at a time one stick was solid as a rock, and the other gave me BSOD all the time. Both were tested in the same memory slot.
So I RMA'd the memory for a refund, and ordered myself some more replacement stuff. This time I went for some Corsair XMS3. Unfortunately in my hurry to get the replacement memory I messed up and got some 1333mhz stuff :/ I dropped it in the machine anyway, and ran memtest and then prime95 to stress things out, and everything seemed good. But my bro-in-law said that I should really get the 1600mhz stuff if I'm planning on overclocking the 2500K at some point in the future. This is definitely on my todo list, so I figured 3rd time lucky, I'll order some more memory, this time Corsair Vengence 1600, and then return the stuff bought in error.
This morning the Vengence memory arrived and I plug it in. From the first attempt to power on I knew things weren't right. The machine reset itself a couple of times before even attempting to POST. I couldn't believe it, surely I haven't got two lots of duff memory?! So I started doing the tests again. One stick works fine and the system is solid, and the other causes rapid BSODs. I've tried sticks together, on their own, in the same slots, in different slots... You name it.
It just seems too weird for this to be massive bad luck on my part. Can anyone offer some advice as to why my system doesn't seem to like 1600 memory? The board supports it according to the specs. And I've tried a couple of different brands. I think the fact that the 1333mhz stuff runs perfectly proves that the memory slots / controller are functioning properly. I've even managed to run both 1600 chips through a full memtest pass without a single issue being reported. But as soon as I try to boot into windows everything falls apart
I have updated to the latest Ua5 bios, and I still experience the same crash happiness whenever I plug in the 1600 memory
All these memory modules are 1.5V, I'm not doing any overclocking at all, the bios is pretty much set to the defaults of AUTO for everything.
Any advice will be greatly appreciated.
Cheers.
i5 2500K
Cheers.
