- 31 Aug 2010
My current system is,
i7 930@4GHZ 1.3v HT on
Corsair H50 Push/Pull
Asus Rampage GENE II
3x2gig G.Skill Ripjaw DDR1600
HIS ATI 5870 1GIG
Corsair HX650watt
2xLG 24x DVD writers
2xSeagate 1TB RAID0
Black Magic Intensity Pro(games used to crash before I added this)
The Problem I'm having is this machine crashes small fft on prime pretty quick (under 10mins) everytime even at stock speeds. But can run blend all day long and LinX 20pass 52glops. Also when gaming the whole system tends to lock up after a few minutes requiring a reboot in games like COD4/BFBC2.
I have tried increasing the Vcore by quite a bit and it made no difference. I tried flashing the GPU with the ASUS 5870 bios but also made no difference. I tried disabling Intel Vitualization in the BIOS and it seemd to make a difference but games tend to take about 30mins to crash then(don't ask me why). I'm running the latest BIOS available from rog.asus.com and I have no clue what the issue is here. I first thought it was the GPU but after testing small fft in prime and seeing it crash so fast I haven't a clue why it's doing that. Does this mean the processor needs to be RMA'd or Motherboard. I only seem to have stability issues with gaming and prime95 small fft. I can render HD stuff in programs like sony vegas and it eats up 100% cpu and most of the ram and the system runs just fine. If the machine is crashing at everything stock then surely some hardware or even hardware setting is causing a fault?
I would appreciate any help on this issue because I'm stumped.
Settings on OC(not that it matters):
BLCK:191@21x
QPI/DRAM: 1.35
DRAM Bus:1.63
PLL: 1.85
ICH: 1.25
IOH: 1.25
Speedstep off C1E off
HIS ATI 5870 1GIG
Corsair HX650watt
2xSeagate 1TB RAID0
BLCK:191@21x
QPI/DRAM: 1.35
DRAM Bus:1.63
PLL: 1.85
ICH: 1.25
IOH: 1.25
