Okay, having some stability issues with my overclock so have dropped the clocks back a tad. Prime95 runs without errors but SP2004 (which I am sure is based on Prime95?) stops responding and has to be 'end tasked'. Both are run using Large FFT (not at the same time).
When SP2004 stops responding the PC is still running fine, it's only SP2004 that crashes.
Is SP2004 the more trustworthy test or is Prime95 the one to trust?
