Just upgraded my dads comp to 939. Went for a dfi rdx200 and, 146 cpu and a 7600 gpu. Dad mentioned that he occasionally got BSOD's before the upgrade.
Put eveything together and kept bsod'ing in windows instalation. Changed gpu and psu and no difference. The memory is 2 x512 corsair 4400. Timings are at 2.5,4,4,8,1t (default). When just running 1 stick (doesnt matter which) everything is fine even at 275mhz @ 2.75v (stock). Put cpu at stock at 200mhz with ram at 2.69v and it bsod's. As soon as put 2 sticks in it bsod's.
Could it be the board or cpu at fault and not able to handle 2 sticks or is it def memory? Weird that memory rated at 275mhz @ 2.75v cant run at 200mhz @ 2.69v
