- 26 Jan 2006
Hey
Any ideas on how I can get my system to become stable?
At the moment, superpi fails - not exact round errors etc.
Im not quite sure why, this is some of the first overclocking iv ever done today, so really dnt know what to try
Rig:
asrock 939 dual sata (I volt modded it earlier today)
2 x 512 RedLine's XP4000@ 3.2 @ 222.8 CPU/11 2-3-7-11
FSB 272 Multi 11 (clock 2.45)
Winchester 3000+
Iv tried changing from 1T to 2T without avail, I also tried pumping the vcore up to 1.475 - 1.5 wouldnt post. CPU temp is 31 under load.
Any ideas what to try? Should I change memory timings and how? or is the CPU overclocked too much?
Rig:
Winchester 3000+
. You've volt modded it but are you sure that it's worked correctly - are you getting correct voltages reported in BIOS and in windows?
