stacked 120mm aio
5 Oct 2014
Hey guys, just a quick question.. i have since moved away from the Open loop.. iv had years on and off with bleeding problems. so i have moved back to AIO, i have a evga DG 86 case, with 2 gtx 980's... the question is, is it a good idea to stack the Rads from the Nzx10 g10's from the gpu's? how much would it affect cooling if at all?, for example lets use "D" as the rad and "F" for the fans, im thinking of doing this with it DFDF would it work? kind regards.
The second rad gets waste heat from the first as such you raise the ambient temp for the 2nd.
If its on the same loop you are reintroducing heat back into the loop.
If its a separate loop you will just have a far higher ambient temp so mostly undo the good of having a low water temp to start off with.
Its not really recommended.
