Very quick sanity check here...
Am creating a network that will utilise 6 x switches and they are going to be stacked. Running over it there will be 2 x VLAN (data and management) and am going to enable ip routing so that I can utilise a server to access the management side of things.
Question is do I need to enable ip routing on all switches? As they are stacked they should appear as 1 switch, but if not enabled then would this stop inter VLAN traffic?
