What is the line in the 'user' config file that handles when trees and such turn 2d or 3d depending on the distance from you? My config tweaks are doing good so far, with the last change I'm after being that I'd like to keep all the trees and such as 3d objects, no matter what the distance is.
If you're unsure of what I mean, here's a link to a screenshot:
http://img465.imageshack.us/img465/8671/ssbreandan032907235247ldn4.jpg
The trees closest to me are fully 3d, while the trees furthest away are 2d sprites. I'd like to eliminate that, but I don't know what the line for that is in the user file. Thanks in advance for helping.
