stalker with complete mod
27 Dec 2003
My laptop easily meets the stalker requirements but does the complete mod take the requirements much higher?
my laptop has
8gb ram
Nvidia GT435M
Intel I7 740
I should think if you can run the vanilla game well you should be able to run the mod. I think it does require some extra power, so I guess there would be a performance hit but I don't think it's that bigger difference (from my experience)
You'll be able to run it, but I doubt with high settings as the gpu is the weak link there. The cpu and ram are more than adequate.
