STALKER - Won't load in Vista - Help?
15 Feb 2006
Staffordshire
Got STALKER last night.
Makes an excellent coaster - won't get past loading splash screen without xray engine error report box (which, incidently, doesn't work either.)
To say I'm unimpressed would be a gross understatement.
Any Ideas Please?
System spec as follows:
FX 60 @ 3.2Ghz
Asetek WC Xtreme
Asus A8N SLi Premium
2GB Corsair XMS 4000 Pro
2 X WD Raptor RAID 0
Gainward Bliss 8800GTX
Dell E207WFP 20" Widescreen (1680 X 1050 @ 60Hz)
Creative X-Fi Platinum
Vista Home Premium 64
Cheers
AndyOcUK
OcUK Tech :mad: :confused:
a stab in the dark but perhaps better than nowt i dare say..
goto:
C:\Documents and Settings\All Users\Documents\STALKER-SHOC
edit with notepad:
user.ltx
search for:
rs_refresh_60hz
and set it to off.
fingers crossed..
STALKER doesnt currently support Vista. Not until they release a patch anywho.
I've got it running on mine though, have you tried running it in compatability mode?
Perhaps installing DX9 might help ? :)
I hear people are getting better frame rates on some games when they have this installed.
I personally haven't got vista yet, so it's just a thought and not a guarantee.
I was actually thinking about getting Vista at the end of the month but I might have to have a rethink, as I'm currently enjoying STALKER.
I hope you get it working as it's a good game :)
goto:
edit with notepad:
user.ltx
search for:
rs_refresh_60hz
and set it to off.
fingers crossed..
Thanks for the replies folks. tried this one....no different.
This is still all I get:
Regards
AndyOcUK
OcUK Tech :( :confused:
Here is the bug report:
XR_3DA.exe caused BREAKPOINT in module "C:\Program Files (x86)\THQ\S.T.A.L.K.E.R. - Shadow of Chernobyl\bin\xrCore.dll" at 0023:002E6024, xrDebug::backend()+740 byte(s)
AndyOcUK :confused:
Yes mate - tried that - also tried run as administrator......still no joy.
Regards
AndyOcUK
OcUK Tech :)
Hi Folks..
Uninstalled and re-installed and its all fine now - works perfectly.
Very, very strange.
Anyway, thanks again for your help and quick responses guys.
Best Regards
AndyOcUK
OcUK Tech :D
juno_first said:
I donb't think Vista can do all the dx9.c effects like HDR, so you may notice some graphics options faded out and an extra 150fps :D
*******UPDATED*******
Runs with everything - not greyed out.
Although is runs like a bag of crap. No Matter what setting, it stutters and the mouse behaves erratically.
Pretty sure my rig should run it no problem (see OP)
What a bloody joke - theres people all over the place slagging off Vista after a 5 year development. lol thought after all the hype surrounding this game they might have actually made sure it worked before releasing it after a 5 year period of B.S. and failed release dates!!! :mad:
Best laugh of all is when I tried to submit the in engine bug report, the bug reporting tool ITSELF CRASHED!!!!!! I almost wet myself....oh the irony....
Anyway.... partying tonight so I'm damned if i'm letting some dumb game ruin my weekend - I've waited 5 years for it so another year for them to write a patch won't hurt I suppose - LMAO!!!
AndyOcUK
OcUK Tech :D
