Hi
My partners car, a 2004 1.6 Mazda 3 saloon has developed an odd issue. When idling, every now and then the revs will die down and the engine light and battery/stall light flash on briefly before the car recovers and idles normally again. Sometimes however it will stall completely and doesn't manage to save itself. It will fire up perfectly again after this has happened.
It has been in the garage and they said the inlet manifold gaskets needed doing as there was a vacuum leak detected there. This was done, but did not solve the problem.
When it seems to nearly die it sounds and looks like the engine is suddenly starved of something (it does kind of look vacuum related).
There are no issues when moving or accelerating. This only happens after the car has been idling for a bit (anywhere between 30 secs and a few minutes).
Any ideas? The garage it is at is now at a loss as to what it is. The only fault code it has thrown up is that the engine was running too lean at one point. However the engine light for this isn't always in and doesn't come back for a while after getting rid of it.
