Hi,
I was putting some new thermal paste on my old XFX3D Radeon HD7870 Black Edition and I noticed that two of the screws that hold the heatsink in place has snapped (with literally no pressure).
The ends of the screws are stuck into the stand offs so they are impossible to remove I assume.
Does anyone know where I can buy some spare stand offs?
I thought they would be the same as the motherboard ones but they have a small lip on the end for it to fit through the GPU.
At the moment I am going to go to my local B&Q and buy M3 machine screws (16mm length) and hopefully that will work.
Is it safe for the end of the screw to touch the pcb?
Thanks
Thanks
