Standalone Flow meter?
10 Jan 2006
Newton Aycliffe
I'm looking for a standalone flow meter with a simple LCD display that will provide minimal restriction flow in the system, this will sit alongside an LCD coolant temp meter.
I've seen that Koolance have something that might fit the bill with the INS-FM18D but nobody seems to stock it.
Are there any other alternatives, not interested in the Aquaero, I dont have front bays.
This is going into an Evolv ATX TG, my idea is i will be mounting the simple LCD screens side by side into slots i will create in the lower compartment shroud, so that they are visible through the side panel.
It looks like this may be my only option then, I'm in no rush as wont be needing till i get round to converting to hardline so I may just order from the US.
Not quite what you are after but alphacool do a standalone flow meter with a 3 pin to read the rpm off a motherboard fan connector and convert to lpm or gpm. I just ordered one for my own loop from the rainforest as paranoid my pump is struggling.
