Star wars Battle front Beta Alpha
29 Mar 2006
Hi Guys,
I apply for the above seem to got lucky as showing in my orgin account.. now here my prob, the min spec required is
•CPU: Quad Core CPU e.g. Intel Core i5-2300 @ 2.8 GHz or AMD Phenom II x4 955 @ 3.2 GHz or AMD FX-8350 @ 4.0 GHz
I have i7 quad so fine
•RAM: 6 GB
I have 16GB fine
•OS: Windows 7 SP1, Windows 8/8.1 (64-bit operating system required)
Fine
•Video Card: NVIDIA GeForce GTX 680 or AMD Radeon HD 7970 with 2 GB of Video Memory
Not good - I have a 660 GTX Msi twin fronzer. Now will this still work?
if not im not fuss but will want to upgrade prob end of aug. I dont want the top of range i want a one that will runs games for next few years and in price range 2-300 so can anyone give some advice what to buy.. Thanks in advance
PS i want to stick with nvidia thanks
970. Not sure you'll get a 980 but you might on a special somewhere. That or a 780ti if you can find one.
Also some games have a hardware block but generally they will run, just slowly.
Ok so see if i can get any in that order 1st.. eg 970? i assume 980 might be out of price range?
Asking now isn't going to get you informed answers, nobody has played it past locked in a desk at E3/closed doors and it might have been on a console.
Wait and see performance reviews, also early access to games may have bad performance compared to release but thats usually a cop-out and excuse by fanboys in my experience :P
You might be able to play it fine.
