Just installed start wars: kotor, and the mouse and keyboard dont work at the main menu and i cant really do anything else, the game doesnt support my current resolution 1920*1080
im using windows 7 64bit
If you're running an nvidia card then try this: I hope this helps you guys. I was having this problems and the way I fix it was by going to the Nvidia control panel, advance settings,manage 3d settings and programs settings.
There I added swkotor.exe Looking at the settings, on conformant texture clamp, I selected "USE OPENGL SPECIFICATION" and since doing this I have not had a random crash in several hours of playing.
In terms of resolutions there is nothing out there change the existing resolutions in the game I'm afraid, not even a widescreen patch so I ran it at 1280x960.
Hope some of this helps cause it's an awesome game
