Pre-empting that Starfield indeed does achieve everything it sets out to, I need a rig upgrade in order to play it!
* AMD R5 5600X
* 16GB (2x8GB) 3600MHz DDR4
* MSI - TOMAHAWK MAX II B450 AM4
* GTX 980Ti + Waterblock
I run a 1440p 144Hz monitor.
As I've got a large watercooling loop I'd like to watercool my CPU as currently it's using the stock air cooler so likely could eek some more boost out of it.
Budget wise I'd say a maximum of £500 for the upgrade, with the assumption that I will get many years more gaming out of it - I purchased my 980Ti in 2018 so it's had a good run. I'm very much out of the loop when it comes to CPU & GPU bottlenecking, or what GPU is good bang for the buck right now.
Currently just playing Apex Legends but likely to play Payday 3, Starfield & the new Cities Skylines in future.
* AMD R5 5600X
