Hi Im looking for advise on setting up a Starlink gen2 home network
My starlink dish and router are located in my workshop where the connection speed is good 180mbs to the router and 200 from device to router.
I am struggling to set up a lan network into the house
my initial setup was to use an ethernet adapter fitted between the dish and router, adapter into a switch and underground cat6 from the switch into another switch in the house distributing to tv, pc , access point ect..this gave me wifi connection to the starlink router in my workshop and lan in the house.
but the lan connection kept dropping out with the only way to reset was to reboot the router.
As a quick work around i replaced the ethernet adapter with a tp link RE550 range extender i had, connected to my starlink router over wifi and connected to the switch via lan giving me internet in the house. a bit of a bodge i know but it works..... although the lan speed has halved from my starlink wifi.
I am now looking to replace the range extender with a router (Archer ax72pro) put the starlink router in bypass mode and try the ethernet connection again hoping the speed and stability improve.as below.
could you guys advise if this is the best network solution with the available hardware of their is a better configuration?
I'm not sure i need the switch from the router in the workshop or if the underground cable can connect straight into the ax72?
ideally i would like the AX72 in the house due to the improved wifi but I'm not sure how this can be acheived still maintaining wifi and lan in the workshop.
Thanks in advance
Thanks in advance
