start button on Lian Li O11Dynamic XL doesn't work
29 May 2020
Hi, i really like this spacious case.
But for some reason, the start/stop button on the front panel of the case doesn't seem to work. This might be a malfunction, or just me not having hooked up all appropriate cables and conncectors, as this is my first build.
Going over all the cables coming out from the font panel, i have thus far connected to the motherboard :
- the 24 pin connector
- a HD audio connector
- usb connector for front panel usb ports
There's two sets of cables left :
- one set connected to a socket soldered on the bottom of the case (pic 1). Can anyone tell what's it's for ?
- another set of tiny cables i guess that are RGB lightning related (pic 2) but need to be sure.
Thanks for any help on this one.
https://postimg.cc/T51xKhw9
https://postimg.cc/t7vyLdSm
The tiny set of cables in Pic 2 need to be plugged into your motherboard. They are not the RGB cables, but the Power Switch, Reset Switch, HDD Activity + Power LED cables. Plug these into the motherboard header (it will be outlined in the motherboard manual) and then you should find your buttons work perfectly.
They normally plug bottom right of the mobo, quite fiddly to do, sometimes it feels like your playing the board game operation.
But as stated above you need to plug the front io in to your mobo to get the switch to work
Glad you got it sorted. The ASUS Q-connector makes things a bit eaiser.
All motherboard manufacturers seem to be rolling out there own version of this now.
I have the same case, great isn’t it.
