start menu help
14 Oct 2007
wubalubadubdub
where have my proggys gone? :(
Right click start bar -> properties -> Start menu tab at the top -> Customize -> Programs.
Any luck?
tryed it...
have just done a fresh install of windows, im using a modded version of XP SP3 with added 'vista features' although i used file/setting transfer to remove these hence the normal XP look, its still 32 bit OS and it works great its just that start menu im having problems with :( i have ran a few progs to try and get some in there but its not working
This might be it. There is a registry value "noinstrumentation" which disables tracking of items for the start menu. Then, only items that you drag and drop there will appear. Actually, it's something I've always done with my windows installs, so I don't get a load of crappy non-matching icons screwing up my mods.
Open your registry and find the key below:
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer
Create, or modify, the DWORD value "NoInstrumentation" and set the value to "0" to disable the restriction.
does it need to be a 'decimal base'?
EDIT: nope its not working, and wont let me set deci anyway it has to be hexi :(
I may be wrong, but it sounds like you might be using a modified version of a specially 'liberated' version of XP, in which case issues are to be expected....
EDIT: DONE IT :D
answer was close to the method in #4...
HKEY_CURRENT_USER
software
microsoft
windows
current version
policies
explorer
then; NoStartMenuMFUprogramsList = 0
and fixed :D
but thanks for help, couldn't have done it without you :p
