Starter Motor Change
6 Jun 2011
Hi all,
Looking for some advice if possible please...
My uncle recently changed the starter motor on my Corsa but I have since had a couple of issues where the car has not started first time. When you turn the key it try’s to turn over but will only start after giving it a second go.
This doesn’t happen every time but has happened on two or three separate occasions now and I’m wondering if it’s a loose connection since the change or something else that could be amiss?
The reason for the change was due to the car not starting at all due to the solenoid getting stuck. A couple of hits and it would start but the change has clearly fixed that issue!
Any help/advice will be greatly appreciated.
