Starter projector kit
22 May 2019
Hi all,
I'm a newbie hoping to get a projector soon.
Any words of advice would be appreciated in terms of screen/projector combo.
Would this screen be any good?
https://www.vonhaus.com/vh_en/100-i...WE3xIaSMfS1U067RU_G8_1U5gMQmYw9BoCywYQAvD_BwE
Anything particular I should be looking for when searching for screen?
Could someone recommend a full hd projector up to £500.
It would be used for mostly watching movies, but I'd also plug ps4 into it.
Distance would be about 3m, also ceiling is high (about 3m) so I guess I could kind of throw downwards?
I'm aware of the audio aspect of this, but this I shall have covered :)
Many thanks
M
AVFORUMS have a buying guide for projectors.
as for projection screen. usually this is something worth spending money on or making your own. there are plenty of guides on how to mix up your own projector paint using easily found paints in stores like B & Q and mixing some stuff found online into it which transforms them.
You then paint wall or paint onto a surface you have created to stick onto the wall.
Thanks but I was hoping for recommendations on actual screens.
Painting a wall (or window in my case) is not an option :)
Thanks
M
For your budget it will all be cheap crap and better to make your own.
A decent screen costs £500-£2000. which means you don't have enough.
In fact a decent budget projector is around £500 so your looking at pretty much nothing leftover for a screen.
AVFORUMS has a dedicated cinema forum.
after looking around i ended up with an optoma 144x as i had a £500 budget and its very feature rich and an awesome bit of kit.
it does video very well and i also play pc,xbox,ps4 on it, all in all its a hard one to beat.
where i fell down is getting cheap screens, i got a excelvan one that i measured by eye from my chair, it was way to big lol but the picture was good, then
i got a smaller vonhaus one and the pic is good but its got a weird shadow on it, like you are projecting through a dirty window at timesm only visible in
really light areas.
still not got another yet but i am reading up a bit now.
finding this out the hard way, will say the excelvan screen was/is way better than the vonhaus and better than a painted wall and for £40 odd pound will
get you started while you save for better.
Sorry, I should have been clearer, budget for screen is seperate thing.
Will cheap one do?
What would be a decent one? Does it make such a big differences?
Thanks
M
Thanks mate ,but before I'll go for DIY I'd like to hear back from users who did not had to make screen.
Regards,
M
the problem is cheap screens use crap material. but you can source decent material for cheap and make your own.
it's the same with using a wall you can make your own projector paint which is better than the ready made stuff.
if you really want to buy a screen then just buy used off ebay or avforums
Hi all,
Many thanks
M
Throwing downwards is a bad idea. The problem is that it creates a distortion of the picture shape. When you project downward, the bottom of the image will look wider than the top. This is because the angle creates a longer distance for the light to travel to get to the bottom edge of the screen than compared to the top edge.
If you haven't had a projector before, then you'll probably gravitate towards electronic keystone correction to 'fix' the picture distortion. In one sense it will work because it will squash the bottom edge width and compress the picture height to make it fit the boundaries of the screen. However, it does that by redrawing the image on the pixel grid in a way that introduces a lot of jagged edges (stair casing) to what should be smooth vertical edges. It's like really bad scaling, and made worse because the projected image is so large.
The other problem with electronic keystone is that it can only ever shrink the image within the boundaries of the imaging chip. That means the image gets progressively smaller the more the keystone correction is used. The result is a longer throw distance.
It's common to find that projectors can sit above the top line of the screen they are projecting on to. This is called Offset. The amount of offset varies with the make and model and with the throw distance and zoom setting. Something like the Optoma 144x has an offset of about 17-18cm where the throw distance is 3m and the screen width (not the diagonal) is between 185 and 204cm. This means that with the projector firing level and true, the start of the picture for a full frame 16:9 image will be 17-18cm below the centre line of the lens.
Screens: You can make your own fixed frame screen with various paints ranging from the DIY option by mixing a couple of Dulux colours, or by purchasing specialist screen surface paints (better colour reproduction and sharper focus). What I haven't seen anyone do successfully is make their own electric or manual pull-down screen. This means you're relying on something purchased if you want something that will roll down in front of a window.
With electric screens you have three main components: The screen surface, the motor roller mechanism, and the control system. Since virtually all economy projector screens are made in China, you're getting Chinese electronics and motors. Try to check if it's properly CE rated as opposed to carrying the fake look-ee-like-ee CE mark that they say stands for China Export (yeah, right).
With screen surfaces, it's not possible to make a high performance surface at a bargain basement price. If it was, it would have been done already and I'd be watching my projectors on a surface the equivalent of a Stewart StudioTek 130 but at a tenth of the £2500 retail price. It ain't happened yet, and there's no sign of it coming. So what's the deal with surfaces?
Higher-end screens use fibreglass or fibreglass/vinyl composites to make a flat surface. The fibreglass adds rigidity, and when laid in the correct way, it can help to prevent the ripples and edge curling that are a common complaint with cheaper screens, and yet still go around a 3-4" diameter screen roller. There's a penalty and a catch though. The penalty is weight. The thicker and heavier the surface then the better the roller mech and motor have to be to cope. That leads to the catch which is this all costs money.
In the mid-market you'll find mostly PVC vinyl surfaces and some PVC/fibreglass composites. Various combinations can be laminated together to achieve certain properties such as flatness or light-blocking from the rear. Some of the screen surfaces I sell have micro-engraving and others have angled light reflecting particles embedded in the surface to help with image sharpness and contrast. Within limits, the more you spend the flatter the surface, the better the colours and the crisper the image.
Entry-level screens forego quite a bit of this tech. To save money on the roller and motor strength they use thin vinyl because it's light, but of course it has very poor rigidity so edge curling and rippling in the surface is a big problem. The vinyl surfaces have poor optical qualities resulting in the patchiness mentioned by a previous poster. Compared to better screens, the pictures often lack punch and have a slightly softer focus. Colour quality can vary too for viewers at a variety of angles.
Screen recommendations - For something worth buying to keep, the Sapphire range is pretty good. Their glass fibre composite electric screens start at around the £400 mark for a 92" diagonal 16:9
The sort of screens being sold for anything from £50-£200 are a bit of a lottery. Just see if you can find some reviews, or look at buying something used from a decent brand such as Sapphire, Owl, Screenline, Draper, Da-Lite.
I had a look at cheap screens recently (stand alone) as I've just moved house and had to take down my old setup. Know someone with a Vonhaus and wouldn't rate it at all but this cheapy (~£40) Duronic screen I picked up as a temporary measure is not bad at all - no ripples or edge problems at all - the main compromise is that to get as good picture as the ~£500 ones has a much lower tolerance in terms of seating position (it just can't do as good picture as the more expensive ones if you get too close or too off angle) - I'd say it was fairly acceptable for a starter setup though I wouldn't be using it for a proper installation.
EDIT: Playing around with it a bit more it can't compete with my old setup though - what would have been some of the old seating positions there is a sheen effect and noticeable pixelation like effect starting to creep into the image which goes away when you move to a more optimal position.
I have cheapy PVC screen as well that doesn't have that problem, actually pretty good optically, but its just the screen on its own and you need to nail it to a wall to get rid of the ripples, etc.
Definitely agree with that - I had a look through a few at £50 and the quality is hugely inconsistent from good enough you wouldn't really notice on a starter setup to dire with odd colours and image warping even when the screen appears physically flat, etc.
Thanks folks for the thorough explanation.
Next thing would be the 'rainbow' effect.read about some Belkin 3lcd projectors - yay or nay?
M
Belkin? Are you sure??
It's a name I associate with slightly overpriced AV cables and bits of ***** AV accessories for the bored shopper. I haven't ever seen them do projectors.
DLP vs LCD
There are pros and cons to each. With 3LCD there'll never be any rainbow effect (RBE). However, you'll see the grid structure of the LCD pixel matrix more than you'll see the DLP structure. Black level isn't as good. Colours can be more intense, but whether they're realistic is another matter.
When I first started selling DLP home cinema projectors back in the late 90s, RBE was a problem for maybe 1 in 5 viewers. That's because early DLPs used relatively slow-spinning colour wheels with a clear segment to help with peak brightness. As the chip and driver tech improved it was possible to use faster colour wheel speeds. That, allied to improvements in lamp technology which gave higher light output from lower wattages meant it was possible to lose the white segment without sacrificing brightness.
Are all DLP projectors now perfect for hone cinema? No. Just as with 3LCD, some are designed for home cinema and so have chips and colour wheels designed for better video motion, superior black level, and they're far less prone to RBE for the average viewer. Your small business-focused DLP projectors are the ones to avoid. They're tuned for brightness and displaying largely static images or video where the room has quite a lot of ambient light. No matter what the manufacturer or retired claims, these are not 'also great for home entertainment'.
If you want to see what's decent tech within your budget, just have a look at the number of home cinema brands using each type of imaging system.
Perhaps it was Epson, something I found in Currys what apparently sorts out the rainbow effect.
I'm thinking now...
About 4-5hundreds for projector and up to 200 for the screen.
I'll choose and pass on my picks for your judgement guys :)
Many thanks
M
