Hi all,
I am looking at building a custom 360 case and fitting water cooling to it to try and overcome the well known overheating problem.
I am looking at a cylindrical case, 360 mobo slightly off centre.
Fitting a xspc 360 cpu/gpu watercooling block (£40) and using a Thermaltake CL-W0132 P500 pump (500l/hr & £20-25) as both of these have been used before.
I was looking at building the reservoir into the other side of the case.
I was also considering running the pipes from the block too a 2 fan radiator and then to another 1 fan radiator before heading to the reservoir. This is mainly due to case design. Would just mean making sure it was properly sprayed to stop rusting
My question is, without breaking the bank, any recommendations on fans and radiators??
Also, I need advice on tubing and connecting it all as I have never done anything like this. For instance, the pump in 3/8" and the block has G1/4" thread
Distilled water is best for cooling isn't it?
thanks
thanks
That's utter madness.........I love it!
Can you overclock them too?
