starting a new system build
9 May 2005
i am starting to build a new system want to put the best bits in as i build really want to make a top class games system. which motherboard would you recommend to start me off, any other help would be great. i dont mind the cost going to spend a little time building it.
cheers
What CPU have you chosen? If you haven't chosen one yet I recommend you investigate Intel's Core2Duo lineup. To go with that I'm a fan of Gigabyte's DS3 motherboard.
How much are you willing to spend on the rig?
i have not choosen anything yet. thought i would start at the motherboard and work the rest from there. i have no price limit. just want to play games on it. i have another for working on.
thanks
tbh, start what kind of cpu u want, then get a board that's suited 2 that along with ram cards ect. u dont say if u wanna go conroe, amd.
thats a big start when picking a mobo. more info on what u want, how much u wanna spend, be a big help for us 2 spec u. :)
sorry, i would like to go conroe, also thinking of spending £1,500 or there abouts. just want a system that will play games in great detail.
thanks for the hlp
Intel Core 2 DUO E6600 "LGA775 Conroe" 2.40GHz
HIS ATI Radeon X1900 XT ICEQ 3 SILENT Heatpipe 256MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express)
Seagate Barracuda 7200.10 320GB
G.Skill 2GB DDR2 HZ PC2-6400 (2x1GB) CAS4 Dua
Asus P5W DH Deluxe WiFi (Socket 775) PCI-Express
NEC AD5170 18x18 DVD±RW Dual Layer ReWriter
Scythe Ninja Plus Rev.B Heatpipe CPU Cooler
Creative Sound Blaster X-Fi Xtreme Music - OEM
Lian-Li PC-7 PLUS Black Aluminium Midi-Tower Case
OCZ GameXStream 600w Silent SLI Ready ATX2
Subtotal £939.90
VAT £164.49
Total £1,104.39
not a bad system, went with the asus board, from the grt results it showing, but the intel & dfi boards r getting grt reviews as well now, rock solid boards.
++ u have saved £400 if u had £1500 to spend :)
ps, u probs want a monitor?? should read some of the reviews in mon section, a good few been released in last few weeks :D
