- 31 Aug 2009
- Surrey, UK
I recently picked up Dirt 2 and Bad Company 2 and am noticing a lot of bottlenecking on the CPU.
Q8300 @ 2.5ghz
3GB DDR2
5770
I can run both games on high settings at 1920x1200, or at low, but the frame rate stays roughly the same. My monitoring gadgets on my other screen give a clear picture of what's happening: the GPU can run maximum settings in BC2 and work at around 85-90%, but all four CPU cores are maxxed out. If I turn the settings to lowest, the GPU eases down to about 35%, but the CPU is still at 100% and the frame rate stays where it was.
Aside from the obvious 'get a better CPU', 'overclock', options, what can be done to alleviate a game's CPU load? If anything..
Q8300 @ 2.5ghz
3GB DDR2
5770
