For now, I am not using the Fahmon because I think it can only be used when running as a service which I chose not to do and to run (created shortcuts) when I tell it to, is that description accurate.
PS joined as Team 10
Also I put down as 8 threads as on the guide it says to use 2 for Pentium 4 HT so I reckon it would work with i7 HT as well? Thanks.
This is the screen, is it in working order?
PS Task Manager say 100% CPU usage.
I remember when I used to do seti@home there were different clients you can download like SSE3/4 that optimise the technology (or whatever it does lol), is that the same case with fah? Could not find much info...
Also, is the GPU folding in BETA? Rather wait until beta ends until I try it on my cards...
thanks again for any help
