Anyone ever seen this before? And if so, just what exactly does msdtc.exe do? Is it a critical file? Nothing "bad" really happens no matter if I click "Ok" or "Cancel".
That's used by Personal Web Server and SQL Server - both of which cannot be installed on XP Home. Also it referenced a null pointer (0x00000000) which is extremely rare in a Microsoft program.
Goto the Properties on the file to make sure it really is the real mc'coy.
those errors are commonly generated by failing memory. Allthough just as often when a spyware remover or antivirus remoces the .exe but not the Reg vaule that points to it. This can be cured by running Hijackthis and posting the output
