Hi I,m having trouble with my utorrent and have read that a static ip & Port Forwarding is something to look into , but i have read that a static ip isn,t as secure online as a Dynamic ip i just wanted some feedback regarding this problem thanks
Yes. Your public IP will be dynamic unless you pay your ISP for a static one. In order to get torrents working you need to give your PC a static IP (eg. 192.168.0.2) and then set up port forwarding in your router. The easier way would be to just enable UPNP in both your router and torrent client.
Okay so where do i find this setting ? upnp I have the Asus DSL RC68U and i,m on B.T Infinity which i know throttles the p2p in the evenings and weekends
well i think i stand corrected ! B.T doesn,t throttle p2p any more , because i,m back to 6mb now ! I have a feeling the trouble was the torrents i was choosing to download were all bad !! they wern,t seeding enough people hence i wasn,t downloading anything , so i,m learning ha! i,m also using Qbittorrent which i,m finding amazing ,and no rubbish adware with it like utorrent which i used for years and feel kind of sad how its gone
Grammar mistakes are one thing, but capitalisation in SI prefixes and units is something completely different. I generally don't correct folks grammar unless they are acting superior, but writing SI units properly is important.
