Static noises?
Permabanned
18 Mar 2006
I know this info is a little basic but I guess it's worth a shot on the chance someone might know what is wrong..
Sometimes I'll hear some static noise coming from the back of my monitor (CRT) area.. it usually only lasts for 4-5 seconds and then will either stop for a good hour or so before I hear it again or maybe will do it again a few more times.
Only recently been hearing it and I am a bit confused as to what it is. I've checked that both the power and graphic thingy cables are in properly and they are. The monitor is pretty close to my curtains, which feel like a material that would charge up quite easily...
Anyone have any idea what could be causing this noise?
could be too close to other things, maybe a sign it's on its way out, have you seen whether changing res and/or refresh rate makes any difference at all?
Wouldn't be surprised if it is on it's way out, had it for about 8 years now but it's served me well.
I'll try it on a different refresh rate and let you know what happens..
