Static or Dynamic IP?
11 Nov 2003
Hi all,
I was just wandering what the advantage is to having a static IP. I notice a few ISP's offer a static Ip (Some free, some at a cost)
I am your usual PC user, I play a few online games and also download with some P2P applications.
Cheers
static ip is a plus but you can get around a dynamic ip with ddns which is easier to remember anyway.
You won't see any advantage in using a static IP unless you need to dial in to your pc or have a small website running. Most ISP's will generally have a fairly long lease time for dynamic IP's.
Pro's and Cons for both.
If your not going to host anything, then it doesn't really matter.
I have one, and to be honest, never used it.
Aye, with NTL, I cannot recall the last time it changed :/ Lease time never seems to end!
JonRohan said:
IIRC its based on the MAC key of your router / firewall so it generally won't change.
I presumed it was something like that. Cheers :)
