I have a 140mm Be Quiet Silent Wings 3 PWM case fan (1000rpm) strapped to my GPU and as it is the quietest fan I have ever used I don't really want to swap it up over wind noise but would a static fan create the same noise. My case is quite big and spacious and not full of hardware, it is also completely silent apart from this. The fan is pointed upwards and I can hear the noise start as the fan gets to 50% speed. It isn't the fan itself, it seems to be the noise of the wind going through the spacious case, despite only being a 140mm fan it does throw a lot of air out as I can feel it when I ramp it up to full speed and the back of my case is directed behind my desk and about 4 feet away.
https://ibb.co/GCQVghd
The heatsink is huge and the fan is more than adequate to cool the GTX1070.
I doubt if there is a fix and I will have to get used to it but thought I would ask. I did not notice it in my old case but the case had louder fans on it so now I notice it, I guess it is the vicious circle of trying to get a silent case.
On further inspection I can hear the noise increase with the rpm increase and emitting from the fan/heatsink itself. Could be because the fan is strapped right onto the heat sink (surpised at only 500rpm though) so I may try adding some type of spacer in between if I can like a hollowed out 140mm fan to see if that fixes it.
