Stationary "folder" help
6 Jan 2006
Newcastle upon Tyne
This is driving me nuts trying to find what it is.
Im after a folder/document holder for around 30 pages of A4. Ive seen them plenty times before as when I set up a new ltd company the memorandum and articles come in one, so know they are readily available.
Basically it has a clear front and a card back and the document appears to be stapled together and then the spine glued into the document folder/cover/holder.
This is similar to what Im looking for to give you an idea but if you go to description it appears its held in with clips or something which isnt what Im after.
Any ideas on the name I should be searching for? I could try nipping into the stappler place tomorrow but they arent usually very helpfull at the best of times.
Thanks
Anything that involves glueing of spines would most likely have to be done by a proper Reprographics place. Would binding it not do?
