statup fault,help !
20 Mar 2006
Hi people ive got this fault with my pc been doing it about a month now when i turn it on it loads as normal right to the vista start logo plays the music etc then the monitor cuts to standby so display goes black not sure what happens to comp dont know wether its on or not,if i try turning monitor back on that dont work either i have to reboot in safe mode and then restart.which usually brings it on also somtimes when it starts if i try to connect to internet straight away it does the same and shuts down or indeed view a pic or play a movie or even listen to music.ive run usuall virus checks etc ive diabled nvida start up helper or wheter its called as i was convinced it was to do with grx card now not sure.Also the system ive got is supposed to be overclockerable easily which when i got it i did but when it does this fault it just sets everything back normal.so now its not overclocked anymore and hasnt been for months as i got fed up with chaging settings for nothing,but thats not really a bearing on the fault ive got as fault is still there and overclock isnt.
my specs are
overclock bundle form OcUK
motherboard:abit proIP35
cpu:Q6600 quad core 95w 2.4ghz 1066FSB
mem:OCZ 2GB PC2-8500c5 1066MHz DDR2
psu:corsair TX 750w
gfx:geforce gtx 280 1024MB GDDR3
hd:2x samsung spinpoint f1 sata 2 500 GB
sound:asus xonar dx
os:vista home premium 32 bit
im not sure if my moniter has anything to do with it its a fairly old crt which i havent replaced yet with a new flat screen because of costs.
Its driving me nuts any help would be appricated thanks.
