Right, should probably start with a disclaimer, I don't know why exactly but seen it in other guides so why not?
Disclaimer
I am not responsible for anything that breaks or catches fire or gets electrocuted through you following this guide, do so at your own risk. You have been warned!
Also this is not only my first guide, but also my first build and first mod, so be kind please .
It's also getto as ****, but on the plus side will be free providing you've got some very basic equipment.
What i'm doing
Stealth modding the DVD drive in my Fractal Design Arc Midi. Probably not the most productive use of a saturday ever, but hey ho.
This will probably work with other cases too, but don't quote me on that...
Required stuff
Scissors
Double sided tape
Spare drive bay cover (forgot to get a picture of this, please don't hate me ).
So what did it look like before?
Step uno
First thing is to move the drive back so theres enough space to put the bay cover in front of it without it sticking out and looking **** (well, actually the first step is to turn of and unplug your computer so you don't electrocute yourself. If you've failed this please refer back to the disclaimer...).
Not really sure why I took this shot, but **** it.
Ah this one is more useful .
Step deux
Next you need to snap of the clips on the side of the bay cover (not sure if all bay covers have these, but whatever just use your common sense and you should be fine ). I just twisted it off, but some of the more petit members may need power tools
Gotta love low aperture...
Step さん
This is where the tape and scissors come into play. Fill the bay cover up with tape (I used double sided 'cause its thicker than yo mommas arse , but if you've got a week off work then feel free to use normal tape ). Be careful not to let it drop over the sides when you get to the top, otherwise it'll stick to the case fascia and the drive won't open . Keep checking the fitment so you don't overdo things.
Step ****ing four
Not strictly neccessary, but it was lunch time and I was hungry...
Step cinque (I had to google that one )
Put a strip of tape onto the disk holder bay slot thingy and stick the drive bay onto it. This obviously needs to be double sided tape. Also do this with the drive closed so it lines up perfectly .
Step سِتّ (thank Allah for LearnArabicOnline.com)
Sit back and admire your frankly baller stealth drive!
That's does indeed look baller, but how do I open the drive?
Simply push the lower right (or lower left if you've got a freak drive) and it'll push the button and, you guessed it, open the drive!
This guide is stupidly basic, even a monkey could figure it out on their own, why did you even bother writing it?
**** you
The End
Can't think of anything to write in here other than thank you and goodbye.
Disclaimer
What i'm doing
Required stuff
Scissors
Double sided tape
Step uno
Step deux
Step さん
Step ****ing four
**** you
The End
