I have a 120gb SSD witch frankly is not nearly big enough for steam, now i have heard fabled speak of an app called steam mover to allow me to move some less used games to another drive.
Q1. is it worth bothering Ie. do you notice the difference loading etc.?
Q2. Can you do it the other way with the same benefit (if there is one) as everything is currently on the platter drive.
. If it fails, it won't effect the original installation, as I didn't run as admin on my first go at moving max payne, and it came up with an error message, and it had copied most of the files, but doesn't remove the original ones until it is successful
