More info.
I went out and had to purchase some truck wash today for my new turd.
It was 25 quid for 25 litres and its officially called Traffic 20.
I got mine from DNG industrial supplies in Barwell. Leics. N'r Windy corner for the locals.
I have done my before shots so once i have fully Turd polished the little chavmobile i will post all the pics. Its raining at the moment and although it works just aswell when its cold and wet i do not.
Chavmobile Turd polishing demo car history.
Stolen recovered. Been standing for about a month. Steering wheel bent and gear stick seemingly disconnected and flopping about. No gears can be selected. Been totally Monstered and neglected.
Previous 1st car owners have meant the engine bay is in a poor state due to 106'000 miles and no real care and attention.
Now i think if i can turd polish this up then i or anyone else can see that anythings possible with a bit of trucky.
Bare in mind that although it costs 25 quid it will last one man ages.
Brilliant for Engine bays, Wheels, Underbody etc and if diluted properly you can use rag application to remove all sorts from your paintwork.
WARNING DISCLAIMER.
Diluting this product in use is a MUST.
Also Heavy heavy rinsing is needed.
The paintwork Must be Washed using a Normal car shampoo afterwards and then a Good polish needs to be reapplied.
Gloves should be worn at All times and its a good idea to have a Bucket of clean cold water at hand for an eye rinse if needed. Although a quick blast in the face from your hose is quick and effective.
Items i will use.
Am going to keep this basic so that All have these items at hand around there house somewhere.
1 Garden hose Standard type. No power. Using ONLY COLD water.
1 Dustpan brush. Stiff bristle one.
1 Bucket.
1 pair of Gay white rubber nanny type gloves or any other waterproof gloves.
And thats your lot.
No expensive pressure washers and No massive hot water bills.
And Definetly no i will do that for 45 quid blokes.
Knowing lots of people in the trade i do this whenever the oppurtunity arises.
Its a cheap turd that knowone wants. I spend my time on it and bring it back to the level of a first car purchase. Then after a new M.O.T. it gets sold on to some happy customer.
After fixing the Gear selector/stick and Bending the steering wheel straight it drives really well. Once its all done it will make someone a good little first car.
