steam font is too small
19 Feb 2012
for some reasons when i turned my computer on and brought steam up the font size/zoom has decreased and as such iam now straining to read any text
i havent changed anything, i just loaded steam up to play skyrim and it has reduced the font size
here is a pic
On the iPad at the minute so can't double check this, but holding down the control key and scrolling the mouse wheel tends to zoom in / out the font size on most applications. Might be worth giving that a try.
^^^ That doesn't work in Steam. :)
That looks normal tbh OP, it just looks silly coz you have the Steam window maximised, and Steam doesn't make much use of the extra space.
It looks just the same on here, all be it with a different theme...
this has now been resolved. i didnt even change anything though, windows installed an update (security update :S) and now steam is readable, doesnt fill the window properly but its fine
You misunderstand. I dont have mine maximised.
But whatever, Good job on 'fixing' it. lol
