Steam in home streaming
1 Nov 2013
Hi guys
Do any of you use steam in home streaming ? If so what hardware are you running ?
My Intel g3258 and Intel HD graphics seems to get the job done quite well.
It sometimes struggles over WiFi a little I assume this is the cheap USB Wi-Fi dongle
I use the steam link personally and by setting the distribution between speed and graphical quality fully towards speed running it over wifi seems to work perfectly with next to no issues but it all depends on your wifi speed.
Wifi is a big part, but I once streamed from my PC (lan connected) to a Macbook Pro wirelessly and it worked just fine.
