Steam Link issue on Quest 3
18 Feb 2007
Wirral
Has anyone had any issues with steam link not finding a computer running steam? Seems to happen 9/10 for me where I need to turn Wi-Fi on and off to get it to find my PC.
It doesn't appear to be a Wi-Fi connection issue as I don't have any issues with Quest Link
Are you using a VPN at all? It's very spotty when trying to connect when a VPN is enabled.
No, PC is connected using a CAT6 cable to the router, and Quest over Wi-Fi. Router is the BT SmartHub 2
Sorry. Not really sure. It might be a problem with the Smart Hub getting overloaded. If a restart of the hub fixes it every time, I would say that's where the problem lies. Have you Qos enabled on the router? Maybe disable it? Or maybe try setting a static address for your PC and see if that solves it.
