Steam Machine - worth it ?
16 Feb 2014
North West England
Looking to maybe upgrade my pc at some point , was wondering what everyone's opinion was on these ? I literally only ever use my current setup for gaming anyway so thought it might be a better option .. I've seen one with an i7 @ 4ghz and a 980ti for £1360 , I don't think I'd be able to build a more powerful gaming tower for the same money would I ? And i would be able to plug it into my tv until I can afford a rog swift monitor. Any opinions would be much appreciated:)
Steam machines really aren't worth it right now. Steam is is a steaming pile which is terribly optimised giving way less performance than windows. You'd be better off building your self a nice matx or mitx build
Steam machines perform significantly worse than there PC counterparts at the moment so I'd advice to upgrade your current rig. :)
You will get less performance for more money and a bunch of new hassles most likely software-wise, does't seem like a good deal at the moment honestly.
Thanks for the advice :) ... Going to build a new rig instead , might take me a while though hopefully gonna order a phanteks evolv case tomorrow make a start !
