Steam not connecting - Help?
30 Jul 2004
East Sussex, UK
Howzit guys.
I have just installed steam. Registered my account. However when I click on the Steam icon, it tries to connect, then says:
Cannot connect to Steam Network.
There might be a problem with your Internet connection or the Steam service.
Please go to: www.steampowered.com for more info.
I went to the website and it mentioned something about ports being forawrd on the router...but I can't seem to find out how to do that.
Any help would be greatly appreicated.
Thanks all! :cool:
Shouldn't really need to forward any ports. Mine has always worked fine behind a NAT router.
Have you got PeerGuardian running by any chance?
No, I haven't got that running.
Erm, I copied my friends steam folder to my PC as his one was the updated one. Then I just entered my user name and password.
Could this have anything to do with it?
I really want to login now! :(
Thanks for the reply!
Port forwarding is easy... just go to www.portforward.com and specify your router make and Steam, and you'll see step-by-step instructions.
Other things to check... have you got a software firewall running on your PC? Have you created a rule in that to allow Steam's traffic out?
Lastly, what happens if you install a fresh version of the client instead of copying it over from another machine?
Hi,
1. I have been to that website and it wants me to buy the program. :(
2. I turned off my firewall just incase it was that - no change.
3. How can I install just steam? Do I have to reinstall all the games I got as well (HL 2 ect?)
Sorry, new to this Steam thing. :(
Just reinstalled Steam.
When I open it up, it tries to update...then says:
"Cannont contact the steam network, please try later."
Okay another problem.
I have HL2 and CS installed. However when I try activate the game on steam is says I must Install it first??
Any ideas/
Thanks all!
