STEAM on Server 2003 wont login using remote desktop
8 Mar 2004
Leicestershire
Just installed Steam into a new 2003 vm and im connecting to it via RDP.
Trying to login to steam and the app just sits there doing nowt.
I can login to the steam store on the server just fine but not with the client :(
I've deleted the clientregistry.blob file
Installed latest flash and java
.Net updated.
uninstalled rebooted and re installed
Any thoughts please.?
When you connect via rdp, as you doing so with the /admin option? This logs you on as if you were at the console basically.
How you do it varies depending on the version of RDP, I think the latest one is literally with a /admin at the end, older versions used /console I think.
Yup tried admin option as im using an mmc snapin.
Had a look on the steam forums and it would appear thats its not supported, yet im sure i do it via rdp on my Win7 media centre.??
Oh well back to HLDS tool again and the CLI.
